car knocking while stop on D mode
30,000 MILES • 3 CYL • 2WD • AUTOMATIC
MOHSIN786786
i have a model 1000 cc. all is best except car is knocking on "D" mode during stop and in reverse mode. kindly help. i do these thing throttle body cleaning, insert new plug, all filters changed, clean oxygen sensor, but still same problem there.
Dec 28, 2016 at 2:14 PM
  • 31,937 POSTS
IF the knock goes away with higher throttle setting, get the oil pressure tested also make sure that the oil level is correct and not very low.
Dec 31, 2016 at 6:40 PM
MOHSIN786786
Yes knock goes away on 900 or 1000 rpm...but do u think oil pressure test required in these new model efi cars..
Jan 5, 2017 at 1:42 PM
  • 31,937 POSTS
It sounds like a low oil pressure problem getting the pressure tested is a quick and simple check to see if pressure is below required levels at idle when this is known we can move on to other tests
Jan 6, 2017 at 7:21 AM
