Engine shuts off while driving
116,000 MILES • V6 • 2WD • AUTOMATIC
MARKJOHNSON
  • 5 POSTS
cranks back up. Shuts off and has no power! I believe the battery and alternator are good. Please help point me in the right direction. Thanks for y’all!
Aug 2, 2020 at 11:22 AM
  • 110,248 POSTS
This could be several different things. For example, low fuel pressure, a plugged catalytic converter, faulty crankshaft position sensor and so on can cause this. What I need you to do is simply retrieve diagnostic trouble codes. This vehicle has an OBD1 system that doesn't require a scan tool to operate. All that will be needed is a short jumper wire or even a paper clip.
Follow this link, which explains how to do it:
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Do this and let me know what codes are found.
Aug 2, 2020 at 2:09 PM
