Car keeps stalling out
124,764 MILES
SHAUNA GOMEZ
My car keeps shutting off and overheating. The car shuts off even when it's not overheating. Fuel pump and thermostat just replaced about a month ago. Also my fans don't seem to be working. I believe I checked the right fuse it's not broken heater and A/C are working fine.
Jul 19, 2020 at 8:57 AM
  • 110,251 POSTS
Does it only overheat when the vehicle is in stop and go traffic or does it happen at highway speeds as well?
As far as the cooling fan, when you turn the A/C on, it should turn on as well. Is that happening?
As far as the fuses, I need you to check two of them in the vehicle's fuse box behind the left side of the dash. See pic 2 for fuse and location. In addition to just checking the fuse condition, confirm there is power to it. Follow this link if needed.
Note: Pic 1 is from the wiring schematic showing one of the fuses for the cooling fan. IF you find a bad fuse, make sure to only replace it with the same amperage fuse that is in the vehicle now.
Next, I want you to check for diagnostic trouble codes. You don't need a scan tool for this vehicle. Follow this link and let me know what you find:
https://www.2carpros.com/articles/retrieve-trouble-codes-for-chrysler-dodge-plymouth-odb1-1995-and-earlier-car-mini-van-and-light-trucks
Let me know what you find.
Jul 19, 2020 at 9:25 AM
