Have you had the vehicle scanned for codes? If you have codes could you post them on here. A common fault I have seen on this is the crankshaft and camshaft sensor failing. During a crank no start, with a scanner you can read live data, I would look to see if there is an RPM reading. If it reads 0 while cranking then the crank sensor is faulty. But again, if you have fault codes then please post them up.
SPONSORED LINKS
Wednesday, June 23rd, 2021 AT 9:14 AM
