Car keeps shutting off
100,000 MILES • V8 • 4WD • AUTOMATIC
ASTANCIL
I have replaced both the alternator and the battery twice and had both tested, the mechanic said they were both good but the car keeps shutting off. I charge it over night but it will not hold the charge longer than a day after driving it. The battery light comes on and the car begins to stall and cut back eventually shutting off. I have heard plenty of diagnostics such as wiring. But I really need a solid answer as I am not trying to spend too much money trying to get it tested.
Oct 15, 2018 at 2:06 PM
  • 110,251 POSTS
First, although the battery is good and the alternator is good, is the power getting to the battery to keep it charged?
Here is what I need to know. Follow this link and simply check the voltage at the battery with the engine off and then with it running.
Next, I need you to check if there is a draw on the battery when there should not be. Follow this link and let me know the results.
https://www.2carpros.com/articles/car-battery-dead-overnight
Both of these tests require a basic multi meter/volt meter for testing. They are simple to complete and will help me better answer your question.
Let me know what you find.
Oct 16, 2018 at 10:49 AM
