Car keeps cutting out
115,000 MILES
VERTVERT
My mazda cuts out when I am slowing down to stop. It does'nt do it all the time , but quite often.
Only had the car a week so did'nt know it did this until after I bought it. Could it be something to do with the fuel?
Hope you can help me its getting to be a nuisance!
Thankyou
Jeanette
May 19, 2013 at 8:41 PM
WRENCHTECH
  • 20,760 POSTS
First eliminate all vacuum or air leaks in the system. You may have a bad IAC ( idle air control) but try cleaning the throttle body first. Remove the intake snorkel, have someone hold the throttle wide open for you and scrub the back side of the throttle plate and surrounding bore with an old tooth brush and some carb cleaner. Be sure to spray some into the small holes next to the throttle plate. That should help stabilize the idle. If it still has a problem, replace the IAC.
May 19, 2013 at 11:01 PM
JAGGERJACK06
  • 14 POSTS
is it efi? because i think it is very possible you just have a carbon buildup in your throttle butterfly. i have had this exact same problem before and i fixed by just cleaning out air intake. also for the 323's at every service the idle speed is supposed to be adjusted by adjusting the throttle cable, if this is not done it may cause problems too
May 22, 2013 at 12:32 PM
WRENCHTECH
  • 20,760 POSTS
vertvert.................
Please ignore the last post as it is totally incorrect.
The idle speed absolutely cannot be adjusted with the throttle cable.
May 22, 2013 at 7:37 PM
