Code P0087, car just lost power?
78,000 MILES • 1.2L • 2WD • MANUAL
WOGO0309
  • 7 POSTS
Hello there, any help would be great. my car just lost power last Friday then just wouldn’t start again was stranded for 5 hours until aa turned up I put my OBD scanner on it while I was waiting and had code P0087 Code: Fuel Rail/System Pressure Too Low tried starting it multiple times but no joy and also AA tried as well still no joy so I was recovered to my home address. Now my friends garage come and took it yesterday and I’ve spoken to him this morning and he started it first time and also said it didn’t need towing as it started for him but I also tried every day until Wednesday as it wouldn’t start and I have also tried it up his garage this morning and it starts first time so I baffled as to what it could be and to honest so was he so I’m just wondering if anyone has any idea what could be causing this please.
Jun 26, 2025 at 10:13 PM
  • 55,691 POSTS
The P0087 Code is the clue, I have seen the high-pressure fuel pump go out as well as the low-pressure lift pump inside the tank, when you turn the system on (not cranking) do you hear both the fuel pump come on for about five seconds? If so, I would lean towards the high-pressure fuel pump or the fuel pressure sensor in the fuel rail. I have seen both can cause this problem, this is why the dealer will replace both when having this issue. Check out the images (below). Let us know how it goes.
Jun 27, 2025 at 3:59 AM
WOGO0309
  • 7 POSTS
Thank you very much for your reply I haven’t got the car at the moment it is still up the garage, but I will certainly keep you informed. thank you again.
Jun 27, 2025 at 4:23 AM
  • 55,691 POSTS
Sounds good, let me know if you can hear the fuel pump in the tank come on.
Jun 28, 2025 at 3:21 AM
WOGO0309
  • 7 POSTS
Thanks again for the reply. I’m going up the garage Monday morning but just a quick question and probably a stupid question. Now that the car is now starting normally that this is very likely to happen again and probably soon as I’m just a bit confused as to why it started to start normally after 5 days with nothing being done to it.
Jun 28, 2025 at 4:45 AM
  • 55,691 POSTS
When parts start to fail it can be intermittent, or you got a bad tank of gas which happens.
Jun 28, 2025 at 6:00 AM
WOGO0309
  • 7 POSTS
Thanks again for the reply. I’ve just lost a bit of confidence in the car now and bit wary about driving it as in just over a week I’ve supposed to take it to the airport for my holidays and the my sons graduation both things I surely don’t want to break down on my way to and are 1 hour and 1 and half hour drives so just a bit wary.
Jun 28, 2025 at 6:20 AM
  • 55,691 POSTS
Yep, that is a worry when problems like this occur. This is the hardest problem to fix and can take time FYI. We need a breakout box that records the failure as it happens or hope for a trouble code to be triggered. Bad gas will not be detected by the computer.
Jun 29, 2025 at 2:49 AM
WOGO0309
  • 7 POSTS
Thanks again for replying and pardon my stupidity again, but isn’t that the code that was given out anyway as in the original post? Or is that just like you said earlier just a general code which could point to a number of things?
Jun 29, 2025 at 4:34 AM
WOGO0309
  • 7 POSTS
And if it were bad gas I only ask because I filled it up full myself and then it has only gone like this now it’s down to 1/4 of a tank left so would it take that long for it to go wrong? And I’m also confused by how after 5 days it just started again with nothing being done to it seems very strange to me but like I say I know absolutely nothing about cars!!
Jun 29, 2025 at 4:35 AM
  • 55,691 POSTS
Oh ya, my bad, I deal with so many questions. It is the fuel issue. I would try the sensor first and then if you hear the fuel pump run in the tank it is pointing towards the high-pressure pump.
Jun 30, 2025 at 3:03 AM
WOGO0309
  • 7 POSTS
Yeah I bet! Okay great. I called up this morning it wouldn’t start for him again on Friday, but it did throw up a trouble code for the fuel sensor though.
Jun 30, 2025 at 3:55 AM
  • 55,691 POSTS
Yep, lean towards the sensor or pump. That is what I would do.
Jun 30, 2025 at 4:28 AM
