car just died
213,000 MILES • 3.8L • V6 • RWD • AUTOMATIC
JGLENN420
I started my car made it about five feet and it died. figured out engine not firing. changed out a bad control module and still no fire not sure if three separate coil packs would go bad at once.
Nov 17, 2016 at 2:50 PM
HMAC300
  • 48,601 POSTS
try a different key if you have one it may be a security issue then scan for codes and check fuel pressure with a gauge. finally scan with a professional grade scanner to see if security is acting up on it.
Nov 18, 2016 at 4:24 AM
