Car battery jump?
105,801 MILES • 4 CYL • AUTOMATIC
STEVIE12
  • 55 POSTS
A week ago, had to get a jump battery. It is only three years old since then three more times Alternator is okay, what could be the problem? Thanks
Sep 14, 2022 at 9:39 AM
MIKE H R
  • 3,094 POSTS
get the alternator checked, the voltage regulator inside may be going bad, or you have a short somewhere. Most auto stores can check the alternator, battery, and starter.
Sep 14, 2022 at 9:56 AM
STEVIE12
  • 55 POSTS
A week ago, I was at the park playing radio with car off can that make battery weak I have to jump to get started.
Sep 16, 2022 at 12:15 PM
MIKE H R
  • 3,094 POSTS
check the battery, it might have a weak cell, the battery would charge up, but the cell draws voltage if there is a bad cell in the battery. I have found that even some new batteries have weak cells.
Sep 16, 2022 at 11:19 PM
STEVIE12
  • 55 POSTS
Okay. Thank you.
Sep 17, 2022 at 5:25 AM
  • 110,246 POSTS
I noticed we haven't heard from you for a few days. Have you been able to make any progress? I'm interested in knowing if you were able to get the issue resolved.
Sep 19, 2022 at 11:29 AM
STEVIE12
  • 55 POSTS
No progress. I noticed a rotten egg smell; can that be the battery?
Sep 21, 2022 at 9:10 AM
MIKE H R
  • 3,094 POSTS
I don't know about the rotten egg smell but am thinking it is the acid in the battery making that smell, keep away from the liquid from the battery. It can burn you... In order to have the radio on do you need the ignition on to play the radio?
2carpros.com
Mike
Sep 21, 2022 at 9:42 AM
STEVIE12
  • 55 POSTS
Thanks. I don't have the radio on since starting problems. I do think it's the battery. I will take it to AutoZone tomorrow.
Sep 21, 2022 at 10:59 AM
  • 110,246 POSTS
I noticed we haven't heard from you for a couple of days. Have you been able to make any progress? We're interested in knowing.
Take care
Sep 23, 2022 at 12:30 PM
