Car jerking when accelerating from complete stop
200,000 MILES
TWISTDFAKA
I have a 1993 toyota Camry vienta ultima (Australia). Everything runs fine while driving and reversing but when I stop a traffic lights etc i have problems accelerating. The only way to describe it is bunny hopping (like learner drivers do in manuals). My cars an auto, the rpm seems to go up and down while this is happening. It only happens when I make a complete stop or sometimes if I go uphill after turning a corner. Other than that it drives fine. Any ideas?
Sep 4, 2013 at 7:07 PM
KHLOW2008
  • 41,812 POSTS
Start with a check on the spark plugs and related components.
If the Malfunction Indicator Light is showing, check for trouble codes.
Sep 4, 2013 at 11:46 PM
TWISTDFAKA
Sorry should have mentioned I've changed plug and leads, also fuel and oil filter, tranny fluid. I've just noticed a 3 cm crack in big hose near between engine and air flow meter. Sorry I can't give the proper names as I'm a lousy mechanic. Could this crack be the problem
Sep 5, 2013 at 11:36 AM
TWISTDFAKA
The check engine light hasn't lit up
Sep 5, 2013 at 11:37 AM
KHLOW2008
  • 41,812 POSTS
Yes, any leaks between throttle and air flow can have adverse effect on engine performance.
Sep 5, 2013 at 11:50 PM
TWISTDFAKA
Hi, tape up the hose & she's running like a dream. Going to go get the part on Monday, thanks you just saved me a couple of hundred $$$
Sep 6, 2013 at 7:21 PM
KHLOW2008
  • 41,812 POSTS
You're welcome and have a great weekend.
Sep 6, 2013 at 11:42 PM
