Car is running hot
2003 FORD
20,150 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
JOANN CHANCEY
Change the thermostat .I change the cooling sensor. the fans work. no leaks, fans are working. the needle goes up to hot and drops back down.
Jul 3, 2017 at 11:35 AM
CARADIODOC
  • 34,416 POSTS
Before you get too involved with the elusive stuff, have your mechanic perform a chemical test at the radiator for a leaking cylinder head gasket. That will cause the symptoms you described even though the radiator fan is working.
Jul 3, 2017 at 1:58 PM
