Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Hyundai
Elantra
Engine
Symptoms
Stall at Idle
Shuts off while driving or when braking?
2004 HYUNDAI ELANTRA
380,000 MILES • 2.0L • 4 CYL • 4WD • AUTOMATIC
ARSLANONE
MEMBER
1 POST
The car is shutdown after few minutes, or during when brake press.
And the car is not powerful .
Jul 22, 2023 at 4:32 AM
Experienced Mechanic
It sounds like you may have a vacuum leak at the vacuum brake booster. The booster is mounted directly behind the brake master cylinder.
Check to see if the vacuum hose is leaking or if you notice a hissing when the engine is running.
Images (Click to enlarge)
Jul 22, 2023 at 3:03 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
