Engine idling too high?
8,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
JROB71
  • 6 POSTS
I recently LS swapped my car listed above and for some reason it idles high, I went through the fuel, checked spark. As soon as I let go of the brakes it wants to take off. I don't know what else to look for.
Jan 18, 2025 at 3:31 AM
  • 110,248 POSTS
When you say you swapped it, do you mean the engine was changed? Is it still carburated? If so, there should be a curb idle adjustment via the throttle control solenoid.
Let me know what you are working with.
Jan 18, 2025 at 11:11 AM
JROB71
  • 6 POSTS
I LS swapped it 5.3.
Jan 18, 2025 at 11:12 AM
  • 55,673 POSTS
Is it driven by wire, or does it have a throttle cable? Please go over this guide:
https://www.2carpros.com/articles/engine-idles-too-high
Please go over this guide and get back to us.
Jan 21, 2025 at 1:32 AM
JROB71
  • 6 POSTS
Throttle cable.
Jan 21, 2025 at 2:52 AM
  • 55,673 POSTS
Okay, try to start the engine without the cable just the return spring. Also, Is the IAC plugged in and working? Is there a way you can pull codes?
Jan 22, 2025 at 12:38 AM
JROB71
  • 6 POSTS
I had no code, and yes IAC works. I'm thinking it's the cheap throttle body.
Jan 22, 2025 at 12:44 AM
  • 55,673 POSTS
Yep, that will do it. Does this engine have an EGR valve? If so it can be stuck open. I would remove it and use this video to test it.
https://www.youtube.com/watch?v=DqUCbbKdWf4
Let us know what you find.
Jan 23, 2025 at 1:21 AM
JROB71
  • 6 POSTS
Jan 23, 2025 at 1:26 AM
  • 55,673 POSTS
You are welcome, please let us know what happens.
Jan 24, 2025 at 12:54 AM
JROB71
  • 6 POSTS
I see no EGR Valve.
Jan 24, 2025 at 3:13 AM
