Rough idle and sometimes stalls
140,000 MILES • 0.5L
CHILLY08XB
Car has been giving me problems lately with codes saying it an o2 sensor and MAF sensor. I replaced both O2 sensors and the MAF. It’s been having a rough idle dropping below 509. Sometimes it stalls especially when stopping at lights or idles rough.
Jun 12, 2020 at 6:02 AM
Do you still have the same codes and if so, what are they?
Also, we need to check for a vacuum leak and see if we can find anything as that is the most likely cause of what you are seeing. Here is a guide that talks about this.
Let me know and we can go from there. Thanks
Jun 12, 2020 at 10:54 AM
CHILLY08XB
Yea, I tried the spraying carburetor cleaner on the hoses and nothing changed. The codes it gives now are P0172 and P0101.
Jun 15, 2020 at 6:38 AM
CHILLY08XB
Also, my spark plugs were really black so I changed them.
Jun 15, 2020 at 10:14 PM
Okay. That is great info. You don't have a vacuum leak because the P0172 is actually a rich condition not a lean condition. So this means you have too much fuel. The black spark plugs would confirm this so I attached the testing for this code which is what we need to run through to find the issue. More then likely we have leaking fuel injectors or a MAF sensor issue but we will figure that out with this testing.
Due to the P0101 I am going to suspect we have a MAF sensor issue but since you replaced it is most likely wiring issues or a control module.
Jun 17, 2020 at 9:16 AM
Sorry. I forgot to attach the testing for the p0101 which is where I think we will end up going so you can actually start with this. If it is not wiring then the testing points to a PCV issue so we have a number of things to check.
Jun 17, 2020 at 9:20 AM
CHILLY08XB
Okay, I changed the fuel injectors and I noticed the car idles normal now. But now after changing them I noticed some white smoke coming out of engine bay and exhaust . I’m not much of a mechanic so this is new.
Jun 21, 2020 at 8:47 PM
White smoke may just be condensation or water getting steamed out of the exhaust however, if it does not go away or get better, we have a new issue.
https://www.2carpros.com/articles/white-smoke-or-steam-coming-from-the-exhaust-pipe
If that is the case, we need to get a new post started because others will not find this issue under this heading.
Follow that guide and let us know what you find on a new post and we will work through this. Thanks
Jun 22, 2020 at 12:37 PM
