Car horn not working properly
289 MILES
GABRIELLEO01
My car horn stop working a few months ago. now when I turn a corner to hard or even just a little the car horn will honk.
Oct 8, 2019 at 6:42 AM
This sounds like a clock spring to me. I attached some detail about this to try and explain it a little better.
https://www.2carpros.com/articles/symptoms-of-a-bad-airbag-clock-spring
More than likely when you turn it is making contact and the horn contacts are stuck so when they make contact it sends the signal to the horn. I included the process on how to replace it if you agree that this is your issue.
Let me know if you have questions and we can go from there. Thanks
Oct 8, 2019 at 10:25 AM
GABRIELLEO01
Thank you so much !
Oct 9, 2019 at 12:57 AM
You are welcome. Please let us know if you need anything else or how it works out. The actual repair will help others that have the same issue. Thanks
Oct 9, 2019 at 11:19 AM
