Flashing check engine light, cylinder misfire
13,000 MILES • 0.5L • 4 CYL
GABBY2002
We replaced the cylinders in my car because it said cylinder misfire which would cause the hitching when I drive. The engine light flashes but it still is doing the same thing. The computer is also saying misfire in two of them but the parts are all new. There’s also a coolant leak.
Apr 19, 2020 at 1:42 AM
Can you provide the exact codes that you are getting so that we know which cylinders are misfiring? Then we need to review this guide because there are a number of other things that can cause a misfire.
The flashing engine light means that there is potential damage being done to the exhaust and engine systems as a result of the misfire so we don't want to drive the vehicle until we figure this out.
Lastly, when you say there is a coolant leak, is that an external leak or are you loosing coolant and have no external leaks?
We are going to need to get more info from here in order to figure this out however, let's start with this and we can determine next steps. Thanks
Apr 19, 2020 at 2:02 AM
GABBY2002
It is cylinder 4 and 6. The leak happens when I drive but we don’t see any on the ground. I know some goes into the oil so we change that more often And the computer reader says it’s a spring(s).
Apr 19, 2020 at 2:09 AM
Okay. You said it was a 4 cylinder in the subject line. Did you mean a 4.0L? Otherwise it would not have a misfire on cylinder 6.
Either way, I would highly suggest not driving this until we get it fixed. I think you are doing major damage to the exhaust and engine if you continue to drive. The coolant leaking into the oil is the sign of a head gasket. At this point, if you repair the head gasket that may be all you need to fix. However, if you continue to drive it may need an entire engine.
Let's confirm the head gasket is the issue. Here are a number of guides that will show you how to confirm a head gasket:
https://www.2carpros.com/articles/coolantantifreeze-in-the-engine-oil
Apr 19, 2020 at 12:00 PM
GABBY2002
I have not been driving it. And my dad is replacing the bad gasket for the coolant anyways so that hopefully is it. He just wants to figure out if it could be anything else before spending the money.
Apr 20, 2020 at 2:25 AM
Okay. That sounds good. I would definitely run those head gasket tests in the guide that I attached prior. Once the head gasket is confirmed then run the compression check so you can see which bank the issue is on. It is unlikely that it is both banks so I would want to find out which side so you only have to do that one.
Let me know what questions you or he has. Thanks for the update.
Apr 20, 2020 at 12:07 PM
GABBY2002
Awesome! I will. thank you.
Apr 20, 2020 at 8:13 PM
Okay. Thanks. Keep us updated.
Apr 21, 2020 at 2:14 AM
