Car hesitation?
201,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
CARLAWEBB
Just replaced crankshaft position sensor and running under 2,000 RPMs and a little hesitation still.
Feb 14, 2025 at 10:02 PM
  • 55,797 POSTS
Do you have a check engine light on? If so, let's run the codes to see if any are stored.
Also, there is a fuel filter under the car which I would swap out. Here is the location and how to change it out. I have also seen a dirty throttle body cause this issue as well.
https://www.2carpros.com/articles/engine-hesitates
Feb 15, 2025 at 3:11 AM
