CAR HESITATES WHEN REVING OR DRIVING
200,000 MILES
AKINYEMI22
  • 10 POSTS
I am currently working on a 2002 toyota RAV4, It hesitates when accelerating or reving when its Idle, So I had it scanned and there were numerous trouble codes cylinder misfire cylinder 1-4, So I replaced the old plugs with new ones, after sometime I scanned the car again and the trouble codes were cleared. But the car still hesitates when accelerating or reving it. What could be the cause
Jul 15, 2013 at 12:43 AM
WRENCHTECH
  • 20,758 POSTS
This is going to have to be diagnosed using a scan tool and analyzing the sensor data. It could be many, many different things like MAF, vacuum leaks, low fuel pressure, incorrect temp sensor readings, intake snorkel leaks, etc, etc.
Jul 15, 2013 at 1:08 AM
AKINYEMI22
  • 10 POSTS
I just remembered there was also a code something about MAF I don't remember the trouble code itself but I remember it didn't clear when I tried to clear it, could this be the cause, I was thinking towards the fuel system
Jul 15, 2013 at 1:15 AM
AKINYEMI22
  • 10 POSTS
Also is it possible to do a fuel pressure test with a scanner
Jul 15, 2013 at 2:00 AM
WRENCHTECH
  • 20,758 POSTS
Not on a Toyota
Jul 15, 2013 at 2:03 AM
AKINYEMI22
  • 10 POSTS
So could the MAF be the problem since it displayed some DTC and they couldn't be cleared
Jul 15, 2013 at 2:14 AM
AKINYEMI22
  • 10 POSTS
Hello nobody has given a clear explanation on how I'll troubleshoot the above mentioned areas, I'm still waiting for your reply
Jul 15, 2013 at 4:23 AM
WRENCHTECH
  • 20,758 POSTS
re-read my first reply
Jul 15, 2013 at 4:29 AM
AKINYEMI22
  • 10 POSTS
I have gone through your reply, like I mentioned earlier what should I look out for with the MAF cause I remember having MAF trouble codes
Jul 15, 2013 at 4:40 AM
WRENCHTECH
  • 20,758 POSTS
All of the sensor data has to be analyzed in the scan tool looking for anything out of parameter.
Jul 15, 2013 at 4:44 AM
WRENCHTECH
  • 20,758 POSTS
Most good scan tools will give you expected sensor values.
Jul 15, 2013 at 4:47 AM
