Car hesitates and almost stalls when coming to a stop
193,000 MILES • 1.3L • 4 CYL • 2WD • AUTOMATIC
JORDANNGIAU
  • 34 POSTS
When i was slowing down to a stop coming, the engines runs roughly and hesitates roughly, almost stalling but goes back to normal when i give it some gas...
Had happened to me the second time already, both when the engine is already running for some time and when i am on the road.
Oct 30, 2020 at 11:22 PM
  • 110,246 POSTS
This can be several things. If you haven't already, have the computer scanned to see if there are diagnostic trouble codes. Here is a link that shows how it is done:
https://youtu.be/InIlnsjOVFA
Next, it could be related to an engine vacuum leak or the idle air control valve. Here is a link that shows how it's done:
If there are no links and no trouble codes, then it could be an issue related to the idle air control valve (IAC). It is responsible for maintaining engine idle speed. This part is mounted on the throttle body.
____________________________________________
Here are directions specific to your vehicle to testing or replacing the IAC. The attached pics correlate with the directions.
2004 Toyota Echo L4-1.5L (1NZ-FE)
Procedures
Vehicle Powertrain Management Fuel Delivery and Air Induction Idle Speed/Throttle Actuator - Electronic Service and Repair Procedures
PROCEDURES
REMOVAL
pic 1
1. REMOVE THROTTLE BODY
2. REMOVE IAC VALVE
Remove the 3 screws, IAC valve and gasket.
INSTALLATION
Installation is performed in the reverse order of removal.
HINT: Install the IAC valve with a new gasket.
INSPECTION
INSPECT IAC VALVE OPERATION
pic 2
a. Check that the IAC valve is half open.
b. Connect the IAC valve connector to the IAC valve.
c. Disconnect the ECT sensor connector from the ECT sensor.
d. Turn the ignition switch ON.
e. Check that the IAC valve moves.
HINT: Repeat connecting and disconnecting of IAC valve connector several times and check the operation of the valve.
If operation is not as specified, replace the IAC valve.
f. Turn the ignition switch OFF.
g. Connect the ECT sensor connector to the ECT sensor.
h. Disconnect the IAC valve connector from the IAC valve.
Oct 31, 2020 at 12:07 PM
JORDANNGIAU
  • 34 POSTS
Thank you for the info. regarding the throttle body removal; Do i need to worry about coolant pouring out when i remove the coolant carrying hose from the throttle body?
Oct 31, 2020 at 2:11 PM
  • 110,246 POSTS
I don't believe there are any hoses that need to be removed. It does indicate disconnecting the coolant temp sensor, but that is an electrical connection.
Oct 31, 2020 at 2:33 PM
JORDANNGIAU
  • 34 POSTS
Turns out it does require removal of a pair of coolant hose from the throttle body and lost about an inch off the full line on the coolant reservoir. Took me about 4 hours to finish everything. First, I removed both of the hoses which one of them has rust underneath it, then took out the 3 screws which was also stuck hard, did some hammering and WD40-ing. As inspected, the valve did not rotate freely so i gave it a good clean with some throttle body cleaner and the valve was rotating a lot smoother. Will give it some time to see if the hesitating persists but so far after test driving, it was all fine.
Oct 31, 2020 at 8:21 PM
  • 110,246 POSTS
Glad to hear you got it taken care of. I looked through the directions again and there is nothing about coolant hoses. Maybe it is of a different design.
Regardless, let me know if things change or if you have other questions. Also, please feel free to come back anytime in the future.
Nov 1, 2020 at 10:09 AM
