Engine shut off while driving and will not start, no spark going to the coils?
150,000 MILES • 1.8L • 4 CYL • 4WD • AUTOMATIC
MAFU
I was driving my car and it suddenly stalled on the road. Cranked it a few times but it wouldn't start. Took it to a mechanic and crank sensor was changed. Drove it for 3 days and it stalled on the road and would not start again. Found out that spark had gone again. Checked area around the ECU and found water by the surrounding areas and discovered that one relay (219) was worn out. Changed the relay but still there is no spark coming to the coil packs. Please help.
Jun 21, 2021 at 11:35 AM
  • 110,251 POSTS
The idea that you lost spark can be a few things. The most common cause is the crankshaft position sensor that was replaced. I have to ask, was an OEM part used or was it an aftermarket?
Next, by chance do you have a live data scan tool? If you do, see if there is an RPM signal when trying to start it. If there isn't, the crank sensor is my first suspect. Also, if an aftermarket one was used, it may have failed.
Also, check the wiring to the sensor. It is located on the driver's side back of the engine. They are somewhat difficult to reach, so there is a chance that the connector was left partially on.
I looked all through my manuals to find a pic, but nothing was available. If you are standing in front of the vehicle, look between the strut tower (driver's side) and the back of the engine. It is down very low. I usually use a mirror when I work on them. LOL
Let me know. Also, let me know if you are able to check for an RPM signal, what brand sensor was used, and anything you can think of.
Jun 22, 2021 at 1:42 PM
MARTYSHERMAN450
  • 20 POSTS
Related, no spark issue with mine no codes or light.
Aug 12, 2023 at 7:19 AM
  • 110,251 POSTS
If you have a live data scanner, see if there is an RPM signal when cranking the engine. If you don't, see if the tachometer moves a little when cranking.
Aug 14, 2023 at 3:01 PM
MARTYSHERMAN450
  • 20 POSTS
No codes, no check engine light, i have fuel to the engine just literally no spark the tachometer moves like hair, i have replace the crank sensor, new plugs wires are good so with the coil pack, now i have been doing process of elimination multimeter go nothing from the ICM i couldn't get a read from the ICM by testing it with the ohms so i think that might be the problem but I'm not sure i don't know anything about Audis.
Aug 16, 2023 at 10:53 PM
  • 110,251 POSTS
By ICM do you mean ECM? I ask because it doesn't have a separate ignition control module.
I did a little digging and found diagnostics for the ignition system. It is if one coil isn't working, but you could still test since all are not working.
If you look below, I attached the info. Note: I eliminated part of the directions because it explained how to determine if a coil is bad. Also, the heading indicates testing without a factor scanner. However, it indicates using VAG-COM.
Let me know if this is something you feel comfortable performing.
Aug 17, 2023 at 11:40 AM
MARTYSHERMAN450
  • 20 POSTS
No, i have an ignition control module, it's on my air box. i have no data coming from the ICM with the key turned, but not to start.
Aug 19, 2023 at 6:47 AM
MARTYSHERMAN450
  • 20 POSTS
Mines a 2.8l.
Aug 19, 2023 at 6:50 AM
  • 110,251 POSTS
The 2.8L isn't one that was offered. They offered a 1.8L turbo or a 3.0L V6. I need you to send me a pic of what you are referring to. I can't find evidence in my manuals for either engine having an ICM.
See pic below.
Aug 20, 2023 at 11:39 AM
MARTYSHERMAN450
  • 20 POSTS
I'm an idiot. all there is too it.
Okay, so if the car has a bad ICM i would have to replace the waste of spark (coil pack). i have tested the coil pack, got 12 volts each coil, but when i did ohms, i get nothing, either I am doing it wrong or I'm doing it wrong. i mean i thought there was an ICM and you're the expert saying there is not one and I'm saying there is. not anymore, I'm wrong to the bone, but I'm right about having no spark, but when i pull the gas line from the engine i get gas when cranking.
Aug 20, 2023 at 12:20 PM
MARTYSHERMAN450
  • 20 POSTS
Okay, so its 11.57 ohms each coil tested at.
Aug 20, 2023 at 7:45 PM
MARTYSHERMAN450
  • 20 POSTS
Also, the ICM is in the coil pack, right? So, can the coil pack be fine just a bad ICM? But if that's the case i would have to buy a new coil pack because the ICM is wired into the coil pack?
Aug 21, 2023 at 9:22 AM
MARTYSHERMAN450
  • 20 POSTS
Also, the crank position sensor was bought at AutoZone and put in. Could it be that one was defective off the rip? I have no RPMs when cranking but an ABS light and a triangle with an explanation point with a half circle with an arrow on the end of it, and its yellow/ orange.
Aug 21, 2023 at 9:27 AM
  • 110,251 POSTS
As far as a coil pack, they wouldn't have all gone bad at the same time. If there is no RPM signal, I suspect you got a faulty crankshaft position sensor.
What engine does it have?
Aug 22, 2023 at 11:44 AM
MARTYSHERMAN450
  • 20 POSTS
2.8l
Aug 22, 2023 at 1:26 PM
MARTYSHERMAN450
  • 20 POSTS
When i bought the car i put one in i bought i from AutoZone, do you think i bought a faulty one?
Aug 24, 2023 at 6:46 AM
  • 110,251 POSTS
I'm not sure what to tell you. The engine wasn't used in 2002. It was used in 2001. I'm worried that I could be giving info that isn't relevant. By chance, could you get me the production date of the vehicle? Maybe it is a really early 2002.
Aug 25, 2023 at 11:44 AM
MARTYSHERMAN450
  • 20 POSTS
It says it's a 99-2000.
Aug 27, 2023 at 12:41 PM
  • 110,251 POSTS
Now, that makes sense. If you take a look below, I attached the diagnostics related to the ignition coils and power output. This is for the 2.8L (2000).
Take a look through the diagnostics and let me know if you are comfortable performing them.
Aug 28, 2023 at 11:08 AM
MARTYSHERMAN450
  • 20 POSTS
Hello, can't you dumb it down for me a little this is what i got.
Aug 29, 2023 at 9:08 AM
  • 110,251 POSTS
Basically, you are testing the wiring between the coils and the PCM. Also, you will be checking the coils as well.
Start with the coils. You will need a multimeter. Set the meter to kohms. The coils work as pairs. So, place one terminal on one side and the other on the opposite to get a reading. See pic below. See if they are within the specifications listed above.
See pic below.
Aug 30, 2023 at 11:47 AM
MARTYSHERMAN450
  • 20 POSTS
Yes sir but i have already tested them they all tested similar to every coil, so this is what i did, after work i went to the junkyard borrowed a ECM because i didn't have no codes or anything plugged it in, check engine light, most i have seen it do since i bought the car, okay so i thought I am going to try to start it, it cranked for a second then it supered liked it caught then stopped, but now i have codes, but don't know, eager to hear back from you.
Codes it gave me:
P1850
P1287
P1432
P1433
P1117
P1425
P0106
P0238
Again, used ECM also was off the same make and module and year just it was a manual and mine is an auto.
Aug 30, 2023 at 12:02 PM
  • 110,251 POSTS
I checked two manuals, and half the codes aren't listed for this vehicle. There is a transmission code and air injection code, but I don't feel that would cause what you are experiencing.
By chance, are you getting spark now?
Aug 31, 2023 at 11:25 AM
MARTYSHERMAN450
  • 20 POSTS
I will check in the morning i got tied up with other stuff.
Aug 31, 2023 at 12:26 PM
MARTYSHERMAN450
  • 20 POSTS
Alright i have spark tested with jumper cable negative on battery negative on sparkplug while plugged into spark plug wire. So, i need a new ECM, right?
Sep 2, 2023 at 12:45 AM
  • 110,251 POSTS
Do you have spark? You didn't mention if you did or not.
Also, I have attached the powertrain management wiring schematics below. I highlighted fuses I need you to confirm for me. Interestingly, if you don't have power to the ignition coils (red wire), it could be a fuse or the fuel pump relay. And, for the coil to get power, there is a fuse related to the fuel pump that may be bad and stopping power before it gets to the fuse for the pump.
Take a look. If the fuses are good and you have power to the coil and you know the coil is good, then the module is suspect.
See pics below. Note. fuses 228 and 229 are identified with the additional prefix 2, in the wiring diagram. In the fuse box, they are fuses 28 and 29. See last pic
I had to cut each schematic in half to make them readable.
Sep 2, 2023 at 1:30 PM
MARTYSHERMAN450
  • 20 POSTS
Alright I have spark tested with jumper cable negative on battery negative on sparkplug while plugged into spark plug wire. So, I need a new ECM, right?
Sep 3, 2023 at 2:26 AM
  • 110,251 POSTS
If you have no spark, the CKP is good and the power supply is present, in most cases, that leaves the ECM.
However, haven't you already tried replacing it?
Sep 3, 2023 at 2:07 PM
  • 110,251 POSTS
Hi:
MARTYSHERMAN450
  • 20 POSTS
Not with an actual good ECM i have a manual ECM for my automatic car.
Sep 3, 2023 at 11:03 PM
  • 110,251 POSTS
Okay. I just don't want you to spend money unnecessarily. Let me know how things work out for you.
joe
Sep 4, 2023 at 1:38 PM
MARTYSHERMAN450
  • 20 POSTS
So, Audi discontinued my ECM for that car but with the manual ECM i do have spark. i plug in my old ECM i have no spark, so that leaves me to believe i need one programed to my car.
Sep 5, 2023 at 8:21 AM
  • 110,251 POSTS
That is correct. If the module is replaced, it requires coding/relearning specific to your vehicle. If I recall, (please know this is from memory) once they are coded, I don't think they can be recoded to a different car. You will need to check on that.
Also, you may be able to find a remanufactured one online.
If you look below, I attached the coding directions.
Let me know if this helps.
Sep 6, 2023 at 9:50 AM
MARTYSHERMAN450
  • 20 POSTS
I have bought one online it says plug in and play, it's for my car and i guess it will be here Sept. 11.
Sep 7, 2023 at 3:52 AM
  • 110,251 POSTS
Sounds good. I've gotten them online in the past (remanufactured) plug and play. They always have worked.
Let me know how things turn out.
Sep 8, 2023 at 10:38 AM
