Car has no power at all
214,000 MILES • 2.0L • 4 CYL • FWD • MANUAL
ADOLFO VENEGAS
I went to start my car the other night and i cranked for a second then everything shut off has if i removed the battery it had completely no power i am not sure what it would be, i tested everything. i did run my radiator fans directly to the battery and through a switch to control them but i soldered all the ends and it was working for a few days. now they do not turn on when i turn the switch, but that is strange they are connected directly to the battery and through a switch it should work right. then this happened i am not sure if i shorted my terminals. haha! help me before i blow this car up and end my misery.
Sep 2, 2017 at 2:54 PM
STEVE W.
  • 15,421 POSTS
It could be a simple failed battery. It happens. The internal connections fail and you get no power. Try a load test on the battery to see what you have.
Sep 5, 2017 at 12:08 AM
ADOLFO VENEGAS
Yes, the negative battery cable had corrosion.
Sep 5, 2017 at 1:02 AM
  • 55,782 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers, Ken
Sep 6, 2017 at 5:03 AM
