Car has a hard time starting at times
136,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
SEBASTIANTUDON
  • 30 POSTS
Car turns on no problem but at times when I drive and park it and start it again it take 2-3 tries before it actually starts,it feels like it wants to start but cuts off. any ideas?
Sep 29, 2019 at 5:16 AM
Good afternoon,
When it does not start, how long does it take to start?
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
This could be fuel delivery or a possible crank sensor issue.
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
Can you check the fuel pressure?
Are there any codes set?
Sep 29, 2019 at 7:59 AM
SEBASTIANTUDON
  • 30 POSTS
It’ll start after about 2 or 3 cranks like on the first ones it wants to start but like fails. it feels like it wants to start but doesn’t, but it’s not always only sometimes it happens.
Sep 29, 2019 at 9:48 AM
I would verify the fuel pressure.
Sep 29, 2019 at 10:05 AM
SEBASTIANTUDON
  • 30 POSTS
And how do I go about that?
Sep 29, 2019 at 10:06 AM
You need to rent a gauge at a parts store and check it with key on, engine off and also when it is running.
Sep 29, 2019 at 7:41 PM
