Car hardly drives
170,000 MILES • AUTOMATIC
TANYA33
my dad was trying to go up a hill in the snow a few day ago and could not make it because his tires were not good enough. Well the next day when we went to go out, the car barely started but the bug issue is the car is extremely loud which of course we figure something to do with the muffler because when he looked uderneath the car he noticed the exhaust pipe is broke, but only the car hardly wants to go when its in drive. It will only go really slow. We are just wondering what would cause that, a broke exhaust pipe would not cause it to hardly go would it?
Dec 31, 2015 at 4:02 AM
HMAC300
  • 48,601 POSTS
I tmay be a plugged exhaust or converter. check vacuum at idle on intake and if 15" or below that may be the problem also check fuel pressure with a gauge should be 60 psi key on only
Dec 31, 2015 at 4:07 AM
TANYA33
hes saying he knows its not the converter.
how about the throttle body, could that be the issue?
Dec 31, 2015 at 4:13 AM
HMAC300
  • 48,601 POSTS
I kind of doubt it check the fuel pressure first. I am assuming this is a 2.2L as you didn't give engine size.
Dec 31, 2015 at 5:02 AM
TANYA33
yes it is
Dec 31, 2015 at 5:33 AM
HMAC300
  • 48,601 POSTS
I alreay gave you what it should be check it with key on only
Dec 31, 2015 at 10:48 PM
