While driving white smoke coming from under hood then engine shut off
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
TERRENCE1994
While driving on the freeway my car started slowing down. I got off to closest exit and my car started having white smoke from under the hood and shut off. I jumped it and was able to drive for about 10 to 15 minutes before the car shut off and started smoking once again. there is a leak coming from the water hose when I put water/coolant inside the radiator. what do you think this could be?
Dec 27, 2019 at 6:28 AM
Good afternoon,
It sounds like it overheated from the failed hose. You drove it overheated until it stopped at least 2 times. That tells me you may have damaged the engine from running so hot.
https://www.2carpros.com/articles/engine-overheating-or-running-hot
I would have it towed to a shop and have them check it for engine damage as well as the leak.
Dec 27, 2019 at 6:45 AM
STEVE W.
  • 15,418 POSTS
Your description sounds like a typical hose or radiator tank bung failure. Which it is depends on exactly where the leak is. The smoke was steam from boiling coolant. The repair is to replace the failed parts. However if you ran it that long with low or no coolant it is very possible that you damaged the engine because it ran hot and started to seize up.
I would inspect the hoses and radiator to see what is leaking and what it will take to repair it. Then pull the oil dipstick, you want to see it full of oil, if it looks like hot chocolate or heavy creamed coffee you have got an internal leak and it may cost as much to repair as dropping a used engine into it. If it looks okay start the engine and listen close to see if you hear any odd noises. Don't run it long just long enough to see if it has any serious noises. Next if it seems to be alright, repair the leaking parts and fill with coolant. Now for the hard tests, First a coolant system pressure test. This applies the same pressures that the system sees once it is warmed up but without running the engine. You basically fill the system, pump it up and then wait to see if it holds that pressure.
https://www.2carpros.com/articles/radiator-pressure-test
Next start the engine and see if you get white smoke out the tailpipe or start hearing bad noises. If neither you may have been lucky.
Dec 27, 2019 at 7:02 AM
