Car engine stalling
150,000 MILES • 2.0L • 4 CYL • FWD • MANUAL
KEMOY28
  • 28 POSTS
My celica st162 keeps stalling then turn on and it idles poorly then dies, if I try to accelerate it dies, I cleaned the throttle body today but the problem became worst, it cough, stuttle and gives smoke through the throttle body and maf sensor when ever it stalls or die, please help me fix the problem
Mar 9, 2016 at 10:23 AM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge auto parts rent it.
Mar 9, 2016 at 9:40 PM
HMAC300
  • 48,601 POSTS
should be 33-38 psi with vacuum line disconnected from regulator. check for a vacuum leak as well
Mar 9, 2016 at 9:42 PM
KEMOY28
  • 28 POSTS
Today i clean the throttle body and it start then rev for a minute or so then it dies down and wont start after the rev,I check all the hose for vacuum leak and there was none,what else can i do?
Mar 10, 2016 at 10:57 AM
HMAC300
  • 48,601 POSTS
what I said in first reply
Mar 10, 2016 at 11:40 PM
KEMOY28
  • 28 POSTS
Fixed a few things on it,now it starts and throttle and rev out nicely but after i rev it the rpm goes up to like 4000 and won't come back down till after a long period... when it does come down the rpm keeps jumping at idle... how to fix this issue?
Mar 11, 2016 at 10:03 AM
  • 55,732 POSTS
Here is how you check the codes https://www.2carpros.com/articles/toyota-trouble-code-definitions-and-code-gathering-method-1990-1995 let us know what you find.
Mar 11, 2016 at 1:38 PM
HMAC300
  • 48,601 POSTS
clean throttle plate on both sides and iac hole with choke cleaner and check for a vacuum leak I have no other suggestions/replies to give you
Mar 11, 2016 at 10:22 PM
  • 55,732 POSTS
Have you plugged the spark plugs to see their condition?
Mar 12, 2016 at 4:52 AM
KEMOY28
  • 28 POSTS
No i haven't but I'll check the sparks plug in the morning.
I found 2 vacuum hose that has torn... i replaced them but now it starts and then dies down completely... I'm planning on changing my tps.. when i try to wiggle it the car gives no signal from the tps
Mar 13, 2016 at 5:30 AM
HMAC300
  • 48,601 POSTS
scan for codes like I said in first reply and make sure any vacuum lines fixed are hooked up correctly
Mar 13, 2016 at 6:25 AM
KEMOY28
  • 28 POSTS
I check the plugs and they were dry and smell of gas...
Mar 20, 2016 at 2:56 PM
HMAC300
  • 48,601 POSTS
check for spark and check compression but make sure to scan for codes auto parts does for free. do not guess on part replacement as they may be good.
Mar 20, 2016 at 3:49 PM
KEMOY28
  • 28 POSTS
I can for codes and got obd1 code 24,igniter signal from ecu missing,i fixed it and the check light is gone but now I'm getting an a/c code and the car still dies after starting
Mar 24, 2016 at 4:53 AM
HMAC300
  • 48,601 POSTS
Please check fuel pressure it could be the root of the problem
Mar 24, 2016 at 5:26 AM
