Car engine turns over but does not crank
22,500 MILES • 4.4L • V8 • AUTOMATIC
ANTHONYT101
Drove car fine for last four months no problems except it stalls or cuts off at times while sitting at a red light. I tried to crank one morning the engine turn over but will not crank. I replaced the alternator, starter, plugs, fuses, and ignition coil, still does the same thing. it also keep draining the battery when I try to crank it. it is getting gas into the carburetor. i do not know.
Dec 18, 2016 at 10:07 AM
CJ MEDEVAC
  • 11,000 POSTS
You may want to replace your fuel filter.
A repair manual specifically for your vehicle would aid you greatly in your regular maintenance (knowing what/ when to replace things) and also in repairs.
Other than possible vacuum leaks, my guess is your carburetor may need some tuning(maybe a rebuild).
It is hard to see it from here.
Check for vacuum leaks and tweak on the carburetor for starters.
Here is a guide for vacuum leaks.
I am going to throw in an answer I gave a good while back.
In general it is the same kind of stuff, but this was specifically given to a Jeep CJ.
As I am a Jeep CJ kind of guy myself.
Your 'stuff' may look a little different, the procedures are pretty much the same. (a repair manual might aid in identifying your stuff and any specifics)
I would skip over everything in the post until you get to the carburetor tuning part, see if that part can be "translated" to fit your carburetor. Grant it, this is a long thread, not something quick and simple.
Here is the post. This guy kind of started not knowing a whole lot!
https://www.2carpros.com/questions/jeep-cj7-1985-jeep-cj7-stalls-when-hot
Let us know how things are going.
The Medic
Dec 19, 2016 at 7:41 AM
