Thirty minutes to an hour after turning on A/C engine shuts off
144,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
BIZZYBRAIN
Anytime I turn on my A/C for example thirty minutes to an hour the engine stops working. I will need to wait for five to ten minutes before it starts.
Please what could be the problem and solution?
Feb 21, 2019 at 9:53 PM
  • 55,588 POSTS
If you do not run the air the engine runs okay? If so I would say the A/C system is overcharged. here is a guide to help you check it:
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Feb 23, 2019 at 6:04 AM
