Car engine stopped
57,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
Y777Y
Vehicle listed above has never had any mechanical problem to date and had not been leaking any fluids). It quit while I was backing up, then it started okay. There were no warning lights on. A few minutes of driving later, I heard a ticking, slightly whirring sound from under the car, and it started to lose engine power, labored for a mile and a half, and shut off. It didn't start-up then. There was a quart or more of oil/antifreeze that ran out from the center passenger's side, and under the hood, the antifreeze overflow was at max level, but bubbling fiercely. There was a very hot smell from the engine. The oil dipstick said no oil was present. The shop has only said that they found an antifreeze leak in the motor, and they would be doing further diagnosis. Have any idea what might have happened?
May 18, 2022 at 8:29 AM
  • 110,248 POSTS
If the engine were extremely low, that certainly could have caused it to overheat. Did you notice the coolant gauge in the hot zone?
Also, please remember this vehicle has a 100,000 powertrain warranty, so if there is anything that involves engine repairs, contact a dealer.
Also, please note there has been an issue with oil consumption which required engine replacement in most cases. If that is the case, there should be no charge by the dealership.
Let me know what they tell you so I can better direct you
May 18, 2022 at 2:15 PM
