Car engine spanner light
60,000 MILES • 1.2L • 4 CYL • 2WD • MANUAL
JITYO
When driving on motorway 30 minutes into it the engine spanner light comes on and engine goes on limp mode when i restart the car after 2 or 3 attempts it goes away. And then okay . But always 30 minutes into motorway. i have replaced the air flow sensor. And have scanned the vehicle for code with my obd11 but nothing comes. No codes.
Mar 10, 2020 at 4:05 AM
  • 110,248 POSTS
First, this vehicle isn't offered in the US, so my technical information is limited. The idea that it goes into limp mode could be something related to a different component than the engine. Is your scanner able to read things such as transmission codes or traction control codes?
Next, you indicated that it takes two or three attempts to start the engine after this happens. The next thing that pops into my mind is it could be related to a crankshaft position sensor. This sensor, when going bad, can fail when the engine is at operating temp. Take a look through these links and let me know if the symptoms seem to mirror what you experience:
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
Let me know if that matches what is experienced.
Mar 11, 2020 at 12:41 PM
