Car engine shuts off when in reverse
102,823 MILES
ETHANWAITS21
I have a 1989 Cutlass Ciera Oldsmobile, when I put it in reverse it cuts off. but it is fine when I put it in drive.any ideas?
Apr 15, 2019 at 5:30 AM
Good afternoon,
This happens due to the torque converter is locking up. It is like trying to start out in fifth gear from a light.
How does the transmission fluid look? Is it dirty or discolored?
How long since you changed the fluid and filter?
Apr 15, 2019 at 8:46 AM
ETHANWAITS21
Transmission fluid is a little low, and I haven't changed the filter since I got the car last year.
Apr 15, 2019 at 10:04 AM
Got it.
You can try changing the oil/filter in the trans and see if it helps. If it does not, then most likely the torques converter will need to be replaced.
Apr 15, 2019 at 10:12 AM
ETHANWAITS21
Do you know how much that would cost and if I can replace it myself or do I have to take it to a shop?
Apr 17, 2019 at 12:03 PM
You need a lift and the sub frame has to be removed then the transmission has to be removed.
At a shop they would charge about $1,000.00 to $1,200.00.
Apr 17, 2019 at 5:01 PM
