Engine shuts off, check engine, oil pressure and battery lights turn on
140,000 MILES • 6 CYL • AUTOMATIC
BOBACHAA
Hi, so this morning when I was on my way to work my engine shut off and the check engine, oil pressure and battery lights all turned on. I tried to restart it and it would start but shut off after a second or two. I was able to get my car back home by starting the engine and revving it. It was able to run as long as I was pressing the gas, whenever I reached a red light it shut off out and had to be restarted. Also my MPG gauge is fluctuating randomly from 0-99 MPG. I just added a new battery last night and drove it for able thirty minutes so I do not think it is the alternator, the battery still has charge.
Oct 17, 2018 at 2:33 PM
  • 55,676 POSTS
It sounds like the air intake boot/tube has come off of the MAF sensor. Can you use these guide to check.
https://www.2carpros.com/articles/replace-an-air-intake-boot
and
https://www.2carpros.com/articles/stall-at-idle
lets run the codes as well
Please run down these guides and report back
Cheers, Ken
Oct 19, 2018 at 5:06 AM
