car eats fully charged battery till the battery is fully drained
168,456 MILES • 3.5L • V6 • 2WD • AUTOMATIC
DANNY919
  • 8 POSTS
Which specific fuses can cause this
The Alternator was replaced 6 months ago so i highly doubt that is the problem
Feb 12, 2016 at 9:04 AM
SATURNTECH9
  • 30,868 POSTS
Don't highly doubt that your 6 month alternator can't be bad.Parts these days are far from perfect I have gotten my fair share of bad ones right out of the box or didn't last long till they failed.If the fuse blew that's usually caused by a alternator failing.Do you have a multi meter to do some testing?Also what size engine do you have?
Feb 12, 2016 at 10:59 AM
DANNY919
  • 8 POSTS
i took alternator to auto zone they tested the alternator and said it was working just perfectly and could not get my year warranty replacement because it is working and nothing at all wrong with it (bummer) 3.5 L engine yes i have multi meter
Feb 12, 2016 at 12:08 PM
SATURNTECH9
  • 30,868 POSTS
With the key in the run position engine off you should have battery voltage to all three white wires and the red and white wire?let me know which one doesn't have power and where that wire goes on the alternator?
Feb 13, 2016 at 3:56 AM
