Car shutting off and now will not start
160,000 MILES • V8 • AUTOMATIC
CTOMLIN
The car has been shutting off when stopped and in drive. We had the intake manifold replaced and it is better but still shutting off when stopped but will stay on if in neutral. Now the car will not start at all.
Dec 22, 2018 at 8:36 AM
  • 110,248 POSTS
First, take a look through this link to see if it helps. It discusses the most common causes of a crank no start condition.
Make sure to check if you are getting spark and fuel to the engine.
You will need to use a multi meter and a test light, so here are the directions for that.
I also recommend scanning the computer for trouble codes. Here is a quick video showing how that is done. If you don' t have a scanner, most parts stores will lend or rent a scanner.
https://youtu.be/YV3TRZwer8k
Dec 22, 2018 at 12:24 PM
