Shuts off after driving for a few minutes?
250,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
ANGELJAMES1985
I've already replaced the EGR valve and the MAP sensor. When I'm driving maybe 5 to 6 minutes of driving all the RPMs go to zero and the car shuts off and will not start again until I set for 5-10 minutes. I can't afford any more repairs I don't need. Could a bad coil make my car act this way?
Aug 31, 2022 at 12:42 PM
  • 55,732 POSTS
Yes, it can, there are many things that can cause this problem. When the engine doesn't start, can you get it to start using starting fluid? If not, we need to check for spark.
This video and guide should help us get started:
https://youtu.be/baq_aEWNQ0Y
and
https://www.2carpros.com/articles/engine-stalls
Sep 1, 2022 at 10:20 AM
