Car doors wont open inside or out.
150,000 MILES
LINDSEYWOHLERS77
My car died and when I put the charger on the car the locks were buzzing until I took them off. The car locked two of my doors and now they will not open from the inside or the outside. I tried the key but didn't want to force it. I tried to pull up the lock nothing. Not sure what to do considering I cannot open door to take off panel. of course one of the doors is the drivers side. I cannot get to the fuze box either as it is by the door. HELP. I have to get into my car by the passenger side.
Apr 23, 2013 at 11:45 AM
sounds like the actuator has failed. did you charge the battery??
Apr 23, 2013 at 11:51 AM
LINDSEYWOHLERS77
Yes and before it was just the back door. (car died again) The power locks dont work either but haven't since I got the car. Windows work fine. The car has also been dying a lot lately around corners and excelling. Just got new battery. I have to put it in neutral and rev the engine a little bit to make sure and holds otherwise it will die again. Thanks!
Apr 23, 2013 at 12:18 PM
