car doors
145,000 MILES
CHERSUE52
doors will not unlock elecronically
May 30, 2016 at 4:18 AM
HMAC300
  • 48,601 POSTS
check battery in remote then check to see if the remote actually works it may not. auto parts can check both for your. if it continues have it scanned for codes as it may be a module problem. a local pro will have to do that however
May 30, 2016 at 5:00 AM
CHERSUE52
Doors have always automatically unlocked when put in park after driving, but since having in shop to fix blown head gasket now stays locked. Noticed battery had been off while car was worked on--time on clock was off. Could some switch have been turned off and not turned back on?
May 31, 2016 at 2:39 AM
HMAC300
  • 48,601 POSTS
try what i'm sending you to reprogram your door locks you will want mode 3 which will go by dings or beeps
May 31, 2016 at 5:03 AM
