Car does not start
260,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
RICHARDZ
I have started the car and it does idle, but with no power. when I tried to start again the car will not make any sound.
Feb 28, 2018 at 4:34 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
I assume you mean the starter does not even crank the engine over. If so, to begin, check the battery terminal connections, starting right at the battery. Try real hard to twist both battery terminal connections and if either move any at all, it is too loose. If okay, check the negative battery cable ground for being loose and the positive battery cable being loose at the other end toward and/or at the starter itself, then go on to checking all the fuses starting with the main fuses.
Feb 28, 2018 at 11:22 PM
