Car engine quit while driving and will not start
88,000 MILES
RONNIE RISTER
Hi, my car listed above stopped running on the highway. the first diagnostic was the fuses they are all right. Second was the ignition module, I change all the ignition cap, rotor and distributor, but the car did not start. also, change changed the computer it did not start either. I do not know what else to do.
Dec 12, 2016 at 10:00 PM
STEVE W.
  • 15,409 POSTS
It could be fuel related. You need to narrow down the possibilities. First check to see if the fuel pump is working. You usually can hear them if you open the gas cap and have someone turn the key to the run position. As a second test you could spay a small amount of engine starting spray into the air intake and see if it fires on that.
If you do not hear it try this guide to test the pump.
On your vehicle you should see thirty eight pounds of pressure at idle, and if you remove the regulator vacuum line the pressure should rise to close to fifty psi.
Dec 12, 2016 at 11:27 PM
