Does not start
180,000 MILES • 1.6L • MANUAL
SILVA30
My car doesn't want to start. The battery is fine. Replaced the starter a few months ago, but now my car sometimes doesn't want to start. Nothing happens.
Nov 8, 2021 at 11:58 PM
SQM
  • 6,383 POSTS
Just to clarify, the vehicle will start as normal, but once in a while it will not start, right?
When it does not start, what do you experience?
Does it make any noise? Any clicking?
Do the dash lights come on?
Please let me know little bit more information.
Nov 9, 2021 at 4:33 AM
SILVA30
Everything still comes on like normal, dashboard lights and radio. It doesn't make any noise. There is a clicking sound when I turn the ignition off again
Hope this helps a bit.
Nov 9, 2021 at 12:44 PM
SQM
  • 6,383 POSTS
It sounds like an intermittent issue with the ignition switch. The ignition switch is the electrical component that the lock cylinder mounts to. It has several connectors and pins and over time due to wear and tear it can malfunction and can trigger this type of issues.
Since the Fiesta was not available in the USA in 2006, I am unable to provide the replacement instructions for the switch.
But the switch typically requires removal of the steering wheel.
Nov 9, 2021 at 1:03 PM
