Car does not start
280,000 MILES • 1.6L • 4 CYL • FWD • MANUAL
WERNER+
My car quit running few days ago, two days later it started again. i went to work, went home, went to shop then car shut off again. When i try to start the lights go on and off but car does not start. After a few swings it sounds like the battery is drained, but all lights on dash is clear. Then i try to jump and engine swings again but still car does not start and lights go on an off.
Sep 15, 2017 at 5:41 PM
  • 31,937 POSTS
Sounds as if there is a loose or dirty power or earth cable. start looking here and also get the alternator charge rate tested and also get the battery load tested as well.start here.
Sep 16, 2017 at 8:39 PM
WERNER+
Other sounds that i hear is the relay fuses. when i turn the key the engine does not turn. now but battery is full, if i connect jump cables it swings perfect. but, that is all it does, no start.
Sep 16, 2017 at 9:01 PM
  • 55,816 POSTS
I would check the positive battery cable they has many problems with those in that car. Try moving the cable around to see if the car acts up or fixes itself.
Here is a guide that can help:
Please let us know what happens and upload pictures or videos of the problem.
Cheers, Ken
Sep 18, 2017 at 4:32 AM
WERNER+
Good day
Problem on car is fixed. It was the feul pump that needed to be replaced
Sep 21, 2017 at 6:43 PM
  • 55,816 POSTS
O man, sorry we didn't get to that sooner here is a video of the job being done.
https://youtu.be/D1AyqeftAmA
Please use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers, Ken
Sep 22, 2017 at 3:35 AM
