Car doesnt make a sound when cranking.
76,000 MILES • 3.0L • FWD • AUTOMATIC
BRANDOND2015
We have a 2003 Ford Taurus SE. We installed a new radio a couple of months ago and haven't really had any problems with our car. If we didn't turn the radio off when we killed the car the door locks would lock and unlock continuously. We bypassed the whole security and electrical system when we installed the radio. Tonight we went to crank our car and it didn't even make a noise. The door mirrors blinked on and off and the radio turned on but it didn't do ANYTHING else. Lol but I don't know what to do now. We're stuck at my fiance's Aunt's house and I need help like immediately.
Apr 2, 2016 at 10:01 PM
HMAC300
  • 48,601 POSTS
probably because the way you installed the radio has created the problems. try disconnecting it then try to reset security system to see if it will start. if no manual look online for your car on how to do it. also make sure battery is up to charge and no fuses underhood are blown.
Apr 3, 2016 at 2:01 AM
CJ MEDEVAC
  • 11,000 POSTS
DID YOU USE SOMETHING LIKE THIS TO HOOK ONTO YOUR RADIO?
THIS PUPPY WIRES ONTO THE RADIO WIRES (ON YOUR KITCHEN TABLE) AND
SIMPLY PLUGS RIGHT INTO THE EXISTING PLUG ON THE CAR
NO HACKING INTO UNKNOWN WIRES
NO HOURS OF HUGGING THE DASH
NO GUESSING
NO MUFFED UP VEHICLE
http://shop.advanceautoparts.com/p/metra-electronics-wire-harness-adapter-into-car-cf-whfd4/6050365-P?searchTerm=radio+wiring+harness
THIS PARTICULAR ONE IS FOR A NON-AMPLIFIED SYSTEM (MORE SEARCHING MIGHT NARROW DOWN THE ONE FOR YOUR APPLICATION)
AT THE PRESENT
IF YOU CAN UNDO THE SCRAMBLE YOU MIGHT HAVE
FROM THE SOUND OF WHAT YOU HAVE HAVE DESCRIBED, I'D DRIVE (IF POSSIBLE) OR TAKE THE BATTERY TO AN AUTO PARTS STORE FOR TESTING. THE ALTERNATOR TOO. THIS CAN BE DONE "ON VEHICLE" IF YOU CAN GET IT THERE. THIS IS NORMALLY A FREE SERVICE!
THIS MIGHT AID YOU TOO!
https://www.2carpros.com/questions/2001-dodge-neon-milage-just-want-put-fliuds-their-locations
"TRT41" WAS STILL WORKING A FEW DAYS AGO
LEMME KNOW HOW IT ALL WORKS OUT
THE MEDIC
Apr 3, 2016 at 2:05 AM
