Car does not want to start when it rains
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
THERESA COMBS
Our car does not want to start when it is raining or there is moisture in the air. It sounds to me like it even backfires a little. It turns but will not start.
Jan 2, 2015 at 11:35 PM
HMAC300
  • 48,601 POSTS
Check coils and new plug wires.
Jan 3, 2015 at 12:24 AM
GNDCABCO
I am also having this issue. I replaced coil packs, changed plug wires, air filter,and had it in for a tune up. Dry everywhere under good cannot figure it out. But, same deal damp out will not start.
May 14, 2018 at 2:31 PM
  • 55,859 POSTS
To me it sounds like the engine coolant temperature sensor is shorting when the engine is cold. Here is a guide to help you see what you are in for where doing the job:
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
Here is the location for your car. Check out the diagrams (below). Please let us know what you find.
Cheers, Ken
May 17, 2018 at 4:21 AM
