Car shus off when reaches operating temperature?
168,000 MILES • 4 CYL • 2WD • MANUAL
BEETLEPUNK21
  • 127 POSTS
Hello, I just bought this vehicle a couple of months ago and I noticed that It dies once it reaches operating temperature on really hot days, like around 95 degrees. It will only start once it is cooled down. What could be causing this?
Aug 12, 2025 at 6:08 AM
AL514
  • 5,697 POSTS
Hello, there could be any number of reasons the engine is shutting down when its hot out. It can be a sensor failing when hot, what is more likely is a cracked solder joint in one of the modules in the vehicle. A cracked solder joint will open up when hot and then close back up when it cools off. The difficult part will be determining what module is causing the stall out. When it wont restart, if you turn the key to the On position, do you see a Check Engine Light on the instrument cluster? It should come on for at least a few seconds. If its not, then the engine computer is not powering up. Since this is an intermittent issue, happening only on really hot days, this will be an issue that a technician/mechanic will need to catch when its happening, or duplicate the concern. There is most likely going to be a code stored in the engine computer due to the fault, so you can start with taking the car to a local auto parts store (AutoZone, advance auto, etc.,) and have them scan the vehicle for any DTCs (diagnostic trouble codes). If any are found, write them down so we know what you're dealing with, and we can go from there.
Aug 12, 2025 at 7:29 AM
BEETLEPUNK21
  • 127 POSTS
Fixed! I did end up changing a sensor behind the engine (forget which one it was) and it fixed the issue. Thank you for the help and great information! You guys rock!
Jan 19, 2026 at 11:22 PM
AL514
  • 5,697 POSTS
Thats great news, glad you got it fixed.
Jan 20, 2026 at 4:37 AM
