Car starts and runs fine in park or neutral, shuts off when put in drive or reverse.
Jul 5, 2022 at 10:25 AM
✓Experienced Mechanic
It sounds like the torque converter has locked up/failed. I can be sure if you make a quick video and upload it with your response. We should run the codes to see if any come up that pertain to the torque converter. If you raise the idle by having your foot on the accelerator and try putting it in gear, does it still stall out?
