Just bought this 86 528e and it seemed that it took a long time to warm up before the transmission would work at all. It starts right up in park or neutral but if I put in gear it dies. If you warm it up for 15 minutes, you can use all gears, but if it has to idle at all, such as a stoplight the same problem. I had the transmission serviced and then was told it needed a torque converter. Does this sound right?
Feb 4, 2016 at 2:06 AM
