Shuts off after reaching normal temperature?
140,000 MILES • 3.0L • V6 • 2WD • MANUAL
CMESIMPLE
My car starts fine. Will drive normally for about 7 miles and I down shift going into town and it shuts off. Won't start again until it cools down to cold. Will run forever in neutral.
Oct 11, 2022 at 12:18 PM
  • 110,244 POSTS
What you described sounds like a faulty crankshaft position sensor. When they begin to fail, heat adversely affects them causing the engine to lose ignition spark. Interestingly, this can fail without setting a code.
Take a look through this link and let me know if you feel it mirrors what you experience:
If it does, then when the engine stalls and won't restart, check if there is spark to the plugs.
Here is a link that explains how to check:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Let me know what you find.
Oct 11, 2022 at 1:46 PM
