Will not stay running
75,000 MILES • 5.0L • V8 • AUTOMATIC
ENRICQUE725
The car has a little trouble starting and will only keep running if the gas pedal is pressed in otherwise it shuts off.
May 22, 2021 at 3:17 AM
  • 55,616 POSTS
This is common when you have a vacuum leak or the throttle bore needs to be serviced. here are three guides to go over when fixing the problem:
and
https://www.2carpros.com/articles/stall-at-idle
and
May 23, 2021 at 3:22 AM
