car dies
1997 INFINITI QX60 HYBRID
184,000 MILES
HURDCANDLES
when slowing down, car will shut down, and die... thought was low in fuel... no difference... when in traffic,.at stoplight. car will die... turns over strong, seems like it wants to start, just as i stop turning the key... it may catch, and go, until car slows down again, and again it dies...
mechanic checked with guage the fuel pump... says its okay...
perhaps fuel regulator,,, or ingection problem... a relay... or 02 sensor???
what things should my mechanic check, and in what order...?? thanks
May 4, 2013 at 1:45 PM
  • CAR REPAIR CONTRIBUTOR
you should not have to tell him what to check, if you do, then find another mechanic..
start with basics, compression, fuel pressure and spark checkes.
have it scanned for codes as well
May 4, 2013 at 1:51 PM
