battery light and ABS light comes on and then my car stalls?
100,000 MILES • AUTOMATIC
CHERREL
My car's battery light and ABS light come on and then my car shuts off. I have changed the battery and the alternator, and it is still doing it.
Oct 15, 2024 at 11:32 AM
  • 55,711 POSTS
Usually the engine stalls then these lights come on can you please confirm? It sounds like you have a vacuum leak, or the throttle body needs to be serviced. Let's go over these guides to get more information on the problem so we can fix it.
https://www.2carpros.com/articles/stall-at-idle
And we should run the codes as well.
Please go over these guides and get back to us.
Oct 16, 2024 at 4:06 AM
CHERREL
No, the lights come on, and they go from being bright down to dim, my built in GPS shuts off, then my car shuts off.
Oct 17, 2024 at 8:09 AM
  • 55,711 POSTS
Okay, it sounds like the alternator is not charging, let's run through this guide after jumping the car to get it going again.
https://www.2carpros.com/articles/how-to-jump-start-car-battery-using-jumper-cables
and
Oct 18, 2024 at 4:03 AM
