Car shut off while driving
175,000 MILES • 4 CYL • 2WD • MANUAL
EELEICART
So driving battery light flashes lights dim. Made it to work and back 50 miles round trip. Next morning starts up just fine dies two miles from where I started. Had the alternator check and battery check both passed the tests but it says that voltage is low. How can I fix it?
It’s a Zx2 if that matters..
Oct 19, 2019 at 5:55 AM
Hello there, my name is Roy and I will help you today.
Do you know what the battery voltage was when it was tested?
It sounds like low voltage. That could be from a battery issue or a charging system issue.
Oct 19, 2019 at 6:09 AM
